Fire ball
Old Apr 30, 2010 | 11:46 AM
AP2 S2K's Avatar
get a Bee*R
http://www.neweraparts.com/Default.aspx?ta...=a&productid=17
Old Apr 30, 2010 | 12:30 PM
LcS2000's Avatar
my 240 with an sr20det swap shot flames alot but im sure its due to the blow off valve not recirculating to the intake. our cars dont have a maf though like th 240 did
Old Apr 30, 2010 | 01:31 PM
GateCrasher's Avatar
RX7's can shoot flames.
Old Apr 30, 2010 | 01:43 PM
moogleii's Avatar
who doesn't love fireballs?
Old Apr 30, 2010 | 02:06 PM
SakeBomb's Avatar
Old Apr 30, 2010 | 02:25 PM
daicacharco's Avatar
[QUOTE=whiteflash,Apr 30 2010, 08:19 AM] If memory serves me right it's by running rich and detonating too early (an overly aggressive timing map).
Old Apr 30, 2010 | 02:52 PM
B serious's Avatar
So much fail in this thread.
A N/A car with a test pipe can very definately shoot fireballs. Unburned fuel goes into the exhaust stream all the time and ignites. Without the cat there, the fireball travels through the exhaust and comes out the tail pipe.
If you have mufflers with baffles, it just sounds like loud pops. If the muffler is more straight through, you see a fire ball as well.
It's not going to damage anyone else's car. They'd have to be about 3'' off your bumper literally for it to even start to maybe damage their car. They don't go out like 50 feet. They're just little pops with flames.
My 240SX shot fire balls all the time with the SR20DET. Might have had something to do with a non-recirculating BOV, but that doesn't matter. MAF, MAP, whatever....F.I. gasoline cars are going to shoot fire balls if you don't have a cat.
No, it's not detonating fuel...or whatever else. For WHATEVER reason, if unburned fuel goes past the exhaust valves with enough volume to create a flame....it will create a flame if it ignites.
So if you have a hot exhaust from driving (especially driving hard), and downshift (blipping the throttle), you might get a flame.
If you hit a spark cut rev limiter, you're going to have flames FOR SURE. My SR20DET had a spark cut rev limiter (stock) and a spark cut speed limiter (stock). It would shoot CONSTANT flames if I laid it on one of those. The S2000 has a fuel cut limiter before you start getting too moist.
If a car is shooting fire balls when the throttle is down and you're just accelerating...it means it's probably not tuned correctly. Usually, flames occur when all the fuel hasn't been burned off. Downshifting or between shifts is common and normal for gasoline powered F.I. cars without a cat. It also happens on gasoline powered N/A cars all the time.
In short:
-Unburned volatile fuel + spark/heat source = fire. We learned this in elementary school. Without a cat there to spoil the fire party...it exits out the tail pipe.
-Yes, this applies for NA cars as well.
Old Apr 30, 2010 | 03:29 PM
CapoArgentino's Avatar
Banned
Just slightly tap the accelerator twice quickly while decelerating from 7500 RPM. By slightly I mean maybe 2mm. I recommend you do it while on your way to Hollywood Video to pick up Fast and the Furious 1
Old Apr 30, 2010 | 11:54 PM
wisdom's Avatar
You should get this
so you can do this
Have fun.
Old May 1, 2010 | 01:41 AM
datdude1119's Avatar
i think this thread is pretty fail. But i will admit watching my friends rx7 shoot flames was pretty cool.
