First-Gear Syncro Dead?
Old Jan 25, 2005 | 03:38 PM
FO2K's Avatar
Originally Posted by Slows2k,Jan 25 2005, 04:22 PM
Yes. All the gears in the trans are synchronized, even reverse.
Not a good thing to post here - some people might believe that and F**K up their transmissions.
Old Jan 25, 2005 | 03:43 PM
Slows2k's Avatar
It's still true.
The trans is equipped with a syncho ring on every gear, some of the gears even have double cone synchro.
This doesn't mean you can shift into reverse while rolling forward.
Old Jan 25, 2005 | 05:09 PM
tesseract's Avatar
^^^ he is right, all gears in the s2k have at least one synchro. this is why i am confused about the grinding into 1st at 5mph
Old Jan 25, 2005 | 05:32 PM
FO2K's Avatar
Originally Posted by Slows2k,Jan 25 2005, 04:43 PM
It's still true.
My apologies, I just looked in the service manual and saw the reverse syncros.
Old Jan 25, 2005 | 05:36 PM
xviper's Avatar
Try a clutch fluid flush and change and check the pedal for correct adjustment. This may contribute a small part to your problem.
I have found that you can determine at what speed your car will allow an easy downshift into 1st (without double clutching). Each car is different. I've seen cars that can go into first at nearly 30 mph while some can't do it above 10 mph. Like someone already posted, don't force it. With clutch in, move the gearshift into the space just before going into 1st where you feel resistance. Keep a firm pressure on the stick and when the car's speed has dropped enough, it will slide in.
It has to do with the "blocker ring" built into 1st gear. It is purposely there to make a high speed downshift into 1st difficult as doing so when you really don't want to, can have devastating results. Spinning up the tranny in a double clutch rev match defeats the blocker ring.
Old Jan 26, 2005 | 06:59 AM
p0pe's Avatar
If you rev match you shouldn't be locked out... without rev matching I can downshift into 1st at around 5-10 mph. When is the last time you changed the tranny fluid?
Old Jan 26, 2005 | 07:05 AM
Gernby's Avatar
Former Sponsor
How old is your tranny oil, and what are you using?
Old Jan 26, 2005 | 11:07 AM
tesseract's Avatar
i changed it late last year...i think it was in October. Was up at Revenuer's (John?) place with Peter, Jeremy, Matt...
put GM Syncromesh FM in the tranny and the LE 607 stuff in the diff.
not more than 3-4k miles
Old Jan 26, 2005 | 11:11 AM
DustySlider's Avatar
My tranny won't let me shift into 1st unless I'm going 3mph or less.
Frez2k
Jul 24, 2010 02:42 PM
motocrossmann
Jun 24, 2009 07:53 AM
plus20
Sep 30, 2004 12:29 PM
ecnay
Jun 4, 2003 09:20 PM
