First Oil Change
Old Sep 17, 2006 | 10:39 PM
Malakas's Avatar
Default First Oil Change
Well I tried my first oil change today - thanks and props to Xviper's DIY. It went pretty smoothly except for the following little speed bumps that cost me more than a little time:
1. Oil spilled all over (missing my catch can) - lost 20 mins
2. I could not get off the old oil filter. I even tried sand paper in the filter wrench. 1.5 hours and a few bloody knuckles later, that SOB spun loose. - lost 2 hours
3. When I went to grab the new filters my friend picked up for me at the dealer (Russle and Smith) - they were the wrong ones!!! Being Sunday afternoon - I headed to Autozone and bought a Mobil-1 filter. - lost 1.5 hours
5.2 quarts of Mobil-1 later - and the car sounded so smooth. I suppose 6K miles was too long to wait to change the oil. This is first I've had all synthetic - so Im looking forward to seeing how it runs.
I hope the next one takes just a little less time. Thanks for listening to me vent.
Old Sep 17, 2006 | 11:18 PM
KnowledgeIsPower's Avatar
i went to autozone for same reason as you and the mobil1 filters they had didnt fit car my car even though their computer said it would? lost 1 day. haha hope next time goes better for ya
Old Sep 18, 2006 | 06:54 AM
Malakas's Avatar
Tell me about it. All in all - the procedure would be pretty fast if you had the correct filter, and the old filter had not been (I assume) over-tightened.
Im not sure if Mobil 1 filters are any good... but I figured - how bad could they be?
Old Sep 18, 2006 | 08:42 AM
clawhammer's Avatar
My first time it took almost a week. I could not get the oil filter off and had to order the Honda wrench.
Old Sep 18, 2006 | 08:48 AM
SIIK2NR's Avatar
#1....operator error.
#2....try a screw driver and a hammer... punch the screwdriver through the filter and it will come off.
#3....If I lived 1.5 hours away from Autozone, I would be getting my OWN filters from the dealership.
Better luck next time.
Tim
Old Sep 18, 2006 | 09:19 AM
SilverDC2 AP1's Avatar
if dealerships and autostore are that far why dont you just order a case of ten online? no point on wasting gas.
Old Sep 18, 2006 | 09:52 AM
chuhsi's Avatar
Wow... a few tips for next time.
- get your mobil 1 in a 5 gallon jug from wal-mart..$22
- get a fumoto drain valve
- order a bunch of honda filters from hardtopguy.com
Word on this board is that synthetic shouldn't go in until 10k...but i wouldn't worry about it.
Your next oil change should take 10 minutes..hehe..
Old Sep 18, 2006 | 10:36 AM
Krenath's Avatar
Yeah, the screwdriver trick works wonders.
When it's time to take your old filter off, you don't love it anymore. You grab a large screwdriver and drive it through the filter sideways, then you can use it as a handle to twist the filter loose. If you use too small a screwdriver, it can just tear the metal sometimes, leaving you with only half a filter attached to the block. Ugh.
Too large a screwdriver can give you clearance problems when turning, so just find something else to stick in the new hole and turn the filter.
I suppose it's obvious but work mentioning anyway: When you puncture the filter, it'll *always* have what seems like a gallon of old oil waiting to drool on you. Be prepared to catch it one way or another.
Old Sep 18, 2006 | 08:33 PM
OnlyInRio's Avatar
After draining the oil, I use an oil filter cap that I attach a 3/8" socket to that takes off the filter no problem. No messing with screwdrivers, sandpaper, that make a big mess. You can get it at your Honda dealer or any parts store for a few bucks. They come in several sizes and one will fit the S2000 filter. I tighten the filter using a torque wrench (16 ft. lbs.) or going by the numbers on the filter which is a 7/8ths turn. Drain plug torqued to 29 ft. lbs. In goes the oil and done in about 20 minutes.
Old Sep 18, 2006 | 08:34 PM
Malakas's Avatar
I suppose you live to learn - so it was a good experience overall. The trip to autozone took an hour mostly b/c I got lost (new to the area); plus it was so damn hot outside I had to change clothes before going anywhere.
I almost used the screwdriver through the filter - but I got so darn pissed at the thing - I just kept at it with the filter wrench and it finally got off.
I just hand tightened the filter back - definitely not too tight. The drain bolt was somewhere between 30-32 lbs (cheapo torque wrench).
Really it was a comedy of errors -- but the car is so much happier now.
