First service?
Taking in my baby for its "first" service. It's a 05 with 44k miles and there are no records of it being serviced....ever.
Thus my question is..... what do i check?
Read all the "before you buy" threads and a few others but there is no "check list" for this situation.
What do I need to check? I can't drive it in peace without knowing EVERYTHING is good.
You can DIY the air filter and cabin filter pretty much without tools, they're both extremely easy and you could do them anywhere - just order the parts online and follow the DIY's (That would save you some money not having to pay labor on those jobs). I'd also recommend checking your serpentine belt tension indicator and seeing if your belt has stretched and needs to be replaced - might need it, might not, but mine was quite stretched at 50,000. Here's a thread that gives some info on that indicator:
Serpentine Belt
Posts #12-14
Everything else the others have said is spot on, should be good at 44k!
Serpentine Belt
Posts #12-14
If you're going home for the summer, do it then.
I definitely agree with checking the brakes, boots, and bushings. You should also check the elastic straps on the top, and check the soft top frame for burrs.
Seems like you answered your own question then. If you need to, check your regional subforum for a good shop (as stated above) and have everything checked out.
Thanks!
Took in my baby today and they don't know shit....
They don't have any of the fluids or how to re grease the shifter...
Most of the things mentioned above...they didn't know how to do.
The trouble of living in a small city....
