First things to do on S2000
Old Nov 9, 2008 | 01:18 PM
  #21
ahrmike's Avatar
^quoted for truth.
mine was in the secret compartment...didnt know i had it til 1 week later a friend with a s2k showed it to me! hahah
Old Nov 10, 2008 | 10:49 AM
  #22
AeroS2000's Avatar
do the compression test your self. Its easy. the tool cost 50 bucks. my S ran 240 PSI all across. when you do the test make sure someone is holding the meter stright up to get accurate reading.
Old Nov 10, 2008 | 04:50 PM
  #23
ans2k's Avatar
Originally Posted by ikeyballz,Nov 9 2008, 02:18 PM
^quoted for truth.
a week? psht, i didn't know it for about a year!!!!
Old Nov 10, 2008 | 10:29 PM
  #24
mrxwormxsayz's Avatar
when the compression test was done.. the meter wasn't up right it was just leaning over. maybe thats why?
Old Nov 11, 2008 | 03:36 AM
  #25
paulg's Avatar
Where,s my secret compartment ????
Old Nov 11, 2008 | 06:01 AM
  #26
AP_ONE's Avatar
LOL
As per compression results, people often make 2 mistakes while doing this
1) car has to be hot and warmed up for proper readings and
2)Gas pedal has to be put to the floor for accurate results while actually performing test.
thanks
Old Nov 11, 2008 | 07:10 AM
  #27
ans2k's Avatar
The secret compartment is in the trunk. lol
Old Nov 11, 2008 | 08:18 AM
  #28
mlc's Avatar
mlc
We could tell you but we would have to kill you .
Kevin
Old Nov 14, 2008 | 10:27 AM
  #29
KONcept's Avatar
U should be able to do the compression test for free (autozone will lend you the tools).
From what I understand about compression tests, its only important that all the cylinders match up. Higher readings can be due to how the tests were run (apparatus straight, foot on pedal, number of cranks, etc...
I guess ur also betting that the probability of messing up all 4 cylinders is quite low.
I spent weeks looking for the secret compartment...cause i found it on the 1st day and thought there was some magical shit that i have seen yet =(.
Old Nov 14, 2008 | 11:20 AM
  #30
StealthimageS2k's Avatar
its called a secret for a reason. =P I'm sure someone here will tell you.
