fitting remote oil filter0 help needed pls
right im in the middle of fitting my remote kit... the sandwich part where the oil filter mounts to the block, I beleive is the cooler has a couple of hose feeds to it. I need to remove the cooler-so I was wondering whether one hose feed,feeds in and one out? or do they both feed oil in from different sides of block?
should the 1 feed in and one out, then I can just simply bypass the cooler and feed the one to the other.
not sure tho.
if any one could help me would be much appreciated!
not sure tho.
sorry mate, think I misunderstood what you wrote...
are you saying the oil is water cooled? ie water flows into the sandwich plate/cooler, and out again and around the engine?
if so then I can simply joint up the two lines and scrap the cooler yeh?
Yes it is water cooled, coolant runs through those hoses.
you should connect a hose to the fitting on the right side of the block to the black pipe that runs across the timing cover.
nashpotatoes21
04-17-2018 05:23 PM
