Flickering CEL Issue
Old Nov 6, 2022 | 10:23 PM
oliversok's Avatar
Default Flickering CEL Issue
Has anyone experienced their CEL flickering on vtec crossover and/or in the vtec window?? It just flickers faintly. the car doesn't lose power and the power delivery feels ok.
Here is a link to the video:
- Sorry shows toward the very of the video.
Any help is appreciated.
-Chris
Old Nov 7, 2022 | 12:22 AM
windhund116's Avatar
Maybe, use a scanner code reader and see if there are any codes?
Old Nov 7, 2022 | 01:03 AM
Slowcrash_101's Avatar
Those are misfires.
Old Nov 7, 2022 | 10:20 AM
oliversok's Avatar
Thank you!
Old Nov 7, 2022 | 10:22 AM
oliversok's Avatar
Quick Update: so this happens consistently only on light partial throttle and and in the lower rpm ranges. First I thought it was a wiring issues, but now I am thinking maybe tune or out of spec valve clearances? Ill probably end up doing a compression test just in case. Sigh
Old Nov 7, 2022 | 11:11 AM
Automotive Engineering Level: MSc Module: Power Train Engineering (XEM48 component) (kpfu.ru)
Pages 5 and 6 specifically.
Old Nov 7, 2022 | 01:09 PM
Chuck S's Avatar
VTEC? VTEC activation doesn't occur until 6000 rpm at full throttle on a stock S2000. Tach never gets above 4800rpm in those 15 seconds of video.
-- Chuck
Old Nov 7, 2022 | 02:21 PM
oliversok's Avatar
-- Chuck
My engagement is set at 4200 rpms.
Old Nov 7, 2022 | 02:24 PM
oliversok's Avatar
Originally Posted by Slowcrash_101
Thanks for the good info. I will take a more in-depth read when time permits. So far from briefly looking over it, the problem that it is pointing towards is a lean condition on light throttle and also improper valve lash settings. I hope this is what is and not something to do with the head or pistons.
Old Nov 7, 2022 | 02:34 PM
Chuck S's Avatar
Roger that. Still needs WOT. Really shouldn't change cams just blipping the throttle or running at over 4200 without load. The guys with good ears are noting misfires so there should be codes or pending codes in the ECU.
-- Chuck
