Flickering of instrument panel
Old Jun 26, 2010 | 11:50 AM
Croc's Avatar
Default Flickering of instrument panel
i'm new to S2K and got 2007 with 30,000 miles.
today while standing at trafic lights i noticed that fuel&temp gauges flickering at idle.
i turned off head lights - flickering reduced.
i turned off AirCon - flickering reduced more - almost diminished.
AirCon back on and reving to 3,000-4,000 flickering alsot dissappear.
si it really looks like this flickering depends on electric system load and revs.
is this normal?
the car still has 2 months warranty....
Old Jun 26, 2010 | 01:07 PM
D_Spec's Avatar
No. Your altenator is going bad. I just had this happen to me.
Old Jun 26, 2010 | 02:38 PM
Greg W's Avatar
I had very light flickering during idle a while back. Replaced my battery and all is well, so it's not always a sign of alternator problems. Battery had >4 years on it, the most I've ever gotten from an OEM battery, so can't complain. If you're under warranty, take it in to Honda and have them check it out.
Old Jun 27, 2010 | 05:09 AM
Croc's Avatar
i just got workshop manual that i purchased few days ago - it describes very specific tests that can be done to "charging system" to check all its components.
i will go to a dealer and make sure that they doo all those tests.
Old Jun 27, 2010 | 07:03 AM
Petah78's Avatar
I have flickering on my MY00 as well. But my car is still on the original battery so hopefully replacing it will fix the problem. However, many S2K owners have reported flickering issues with their dash so it might just be the design of the car. Just do and search and you will find few threads where this has been reported.
Old Jun 27, 2010 | 07:09 AM
D_Spec's Avatar
If your dash lights flicker it is your alternator. The battery only starts the car. Start your car and disconnect the battery. The car still functions normally.
Old Jun 27, 2010 | 07:21 AM
D_Spec's Avatar
Technally It's the rectifier. But not so simple replace.
Old Jun 27, 2010 | 01:10 PM
f20kills's Avatar
I wouldnt suggest doing that....
Old Jun 27, 2010 | 05:56 PM
R1_Pilot's Avatar
I fought this problem a while back. After taking my alternator apart a few times and changing the rectifier (~$150 from Majestic Honda) the problem was gone. Whether this will take care of your problem or not I am not sure, but it might be worth a try. Btw, it's quite simple to work on this alternator.
J
Old Jun 27, 2010 | 08:46 PM
Just Guy's Avatar
I'm having the same issue. My tech at Honda says it definitely the alternator, I have a open diode (sp?). So I just bought one from someone on here, let's hope that fixes it.
