Fluid change
Old Nov 17, 2013 | 03:40 PM
Brian339's Avatar
Default Fluid change
I am about to do some searching to learn about changing the fluids in my recently bought s2000. It's got 42k on it and I am just not sure about the maintence that's been done. I will do the valves adjustment in the spring.
What do you guys recommend for fluids and I am open to any tips about the procedure and anything else you want to offer to a new s2000 owner.
BTW what an awesome car we own
Old Nov 17, 2013 | 04:34 PM
Rays S2k's Avatar
Well what I use is amsoil but Mobil 1 is great as well I just recently switched my oem transmission fluid for amsoil and what a difference my 2nd gear used to pop off and now it doesn't it's awesome
Old Nov 17, 2013 | 06:43 PM
zmoney610's Avatar
I use:
Motor- RedLIne 5W30
Tranny- Honda MTF
Diff- Mobil 1 75w-90
Just put the right type of stuff in there and change when you should. People will recommend RedLine, Motul, Amsoil, people will say it doesn't matter, people will say it does. Some say don't use Mobil 1, some say they do. Have fun with the S.
Zach
Old Nov 17, 2013 | 08:33 PM
RaceMyGhost's Avatar
I use:
Motor: Castrol Syntec 10w-30
Transmission: Redline MTL 70w-80
Differential: Redline Gear Oil 75w-90
Brakes: Honda Dot-3
Clutch: Honda Dot-3
Old Nov 18, 2013 | 04:06 AM
redlineracing's Avatar
My 03S runs these since 1st change.Now has 94k.
Oil:Amsoil 0w30(Pic)
Oil Filter:Wix 51334
Air Filter:K&N
Trans:MFT (Pic)
Diff;SG 75-110(Pic)
Clutch & Brake:Prestone Dot4
\rlr
carolina
Attached Thumbnails Fluid change-azo-0w30.jpg   Fluid change-mtf.jpg   Fluid change-sg-75-110.jpg
Old Nov 18, 2013 | 04:14 AM
03suzuka...s2000's Avatar
Engine: Castrol syntech 5w30 or 10w30 with OEM filter
Trans: amsoil
diff: amsoil severe gear 75-110
Clutch and brakes: Honda
Old Nov 18, 2013 | 06:05 AM
cosmomiller's Avatar
Top Answer: 1
Read up on this:
http://www.bobistheoilguy.com/motor-oil-101/
I think the biggest thing you should get out of this is to use synthetic (as much as you can in the US) and use a 0-XX oil to prevent as much wear as possible on start no matter where you live and drive.
Personally I use Mobil1 0-30 (Wal Mart $25 5qts) and a Honda filter. I have used Honda MTF but am about to try Amsoil. For the diff I use Mobil 1 Synthetic Gear Lube LS 75W-90.
For the clutch, I use Honda brake fluid and use Billman's method of sucking out the fluid several times (driving between refills) to slowly replace the fluid. Easy.
I don't track (yet) so I just used the Honda Brake fluid for a flush.
Good luck and have fun. Do read up on putting the car on jack stands for safety. Muy important!
Old Nov 19, 2013 | 07:04 PM
NoMoreCivicsPlease's Avatar
Wait... So I shouldn't be running 10w-30????!!!!!
Old Nov 19, 2013 | 07:54 PM
darcyw's Avatar
'03 s2k
Oil:Amsoil 10w30 signature synthetic
Oil Filter:PCX-004 OEM
Air Filter:K&N
Trans:HONDA MTF
Diff;Amsoil severe gear 75w110
Clutch:Honda dot3 brake fluid
brake fluid: Amsoil brake dot3
antifreeze:OEM honda
buy the best your budget allows.
darcy
Old Nov 19, 2013 | 07:58 PM
Top Answer: 1
Oil is a hotly debated thing. Some will go round and round throwing numbers about the difference between 0w-xx and 5w-xx. Read the Bob is the Oil Guy and find out why 0w-30 Synthetic (not dino) is better than 10w-30 anything because it is thinner at start when a lot of wear occurs. All xw-30 oil will be the same at operating temp. No oil is perfect for start but 0w is much better. Read the link and you will know the why.
Your engine will not explode running 10w-30, its just 0w is better for long term wear.
