fluid maintainence
Old May 10, 2007 | 03:43 PM
J's_Racer's Avatar
Default fluid maintainence
can i know how many quart the transmission need ( using MT90 redline) and how many quart the rear diff needs? ( any recommendation?)
thanks a lot guys
Old May 10, 2007 | 03:47 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Dif 1 quart, you'll use 9/10 of the bottle
Trans 2qts, you'll use about 1 and 3/4.
Old May 10, 2007 | 03:55 PM
J's_Racer's Avatar
the only info i found was to use LE-607. i doubt i can get any locally .
what redline fluid will u guys use on the rear diff?
thanks for the help billman. ( wish u live nearer =))
i'll be sending in my car to the mech tmr so i need to buy the fluids in the morning
Old May 10, 2007 | 04:13 PM
jyeung528's Avatar
since people use mobil 75w90, you can use redline 75w90...but make sure you don't get the shockproof (or something like that)...just regular 75w90 gear oil.
billman recommends mobil 1 75w90, why don't you just get that if you can't find le607?
Old May 10, 2007 | 04:14 PM
jyeung528's Avatar
i only use about 7/10, maybe 8/10 for the diff.
should i be tilting the car to overfill a bit?
Old May 10, 2007 | 04:16 PM
J's_Racer's Avatar
thanks guys..... i hope they sell those in wal-mart for the mobil1 75w90..why i should not get the shockproof one from redline btw?
Old May 10, 2007 | 04:20 PM
jyeung528's Avatar
my recollection tells me the shockproof is not good...
for redline, just regular 75w90 gear oil.
Old May 10, 2007 | 04:24 PM
J's_Racer's Avatar
well since s2k has lsd , what additives is needed and what is recommended?
i read on amsoil 75w90 as well. what about that one?
Old May 10, 2007 | 04:51 PM
jyeung528's Avatar
no additives.
amsoil should be fine also.
look, just get mobil 1 75w90 since it comes recommended by billman, or le607.
Old May 10, 2007 | 07:01 PM
J's_Racer's Avatar
i didnt see him recommened it on his post?
