Flywheel install question
Old Feb 28, 2008 | 01:59 PM
wing's Avatar
Default Flywheel install question
Possible to pull tranny out without lowering the engine if you are on a hoist? Or is it impossible to get those top bolts without dropping it?
Old Feb 28, 2008 | 03:39 PM
fadiss2k's Avatar
It is impossible! lol Even with the motor lowered, it is still hard getting that top bolt off. If you use a 2x4 to stable all the extensions, it helps out alot!!! Good luck.
Old Feb 28, 2008 | 04:43 PM
wing's Avatar
Ok thanks! From what I have been reading there are 3 ways of doing this.
The manual tells you to disassemble quite a bit of the engine to get it to drop, I read one guy just took out the engine mounts and voila without disassembling and another mentioned all he did was remove the header (Which I've already done before so that's an easy job for me).
Also I guess I have to buy an alignment tool for the clutch assembly when I replace the fly wheel from my Honda dealer?
Old Feb 28, 2008 | 04:47 PM
wing's Avatar
Oh and here's my motivation for asking.
http://youtube.com/watch?v=X8sdt8cGztM
Looks like all they did was remove driveshaft, cat and heatshield and voila... but maybe they didn't film the other mess.
lpcome
Nov 14, 2017 06:17 AM
2k2_s2k
Apr 12, 2015 12:54 PM
RGlbk
May 26, 2007 12:58 PM
AusS2000
Apr 6, 2007 10:21 PM
willyang
Apr 9, 2005 01:01 PM
