Flywheel step help!
Old Mar 18, 2009 | 07:49 AM
Jreyenga's Avatar
Default Flywheel step help!
Hey all,
I have a race this weekend and I
Old Mar 18, 2009 | 08:02 AM
cdelena's Avatar
Since resurfacing the FW is not recommended by Honda there is no spec.
Old Mar 18, 2009 | 08:07 AM
Jreyenga's Avatar
I'm well aware of what honda recommends and that there is no spec in the shop manual.
But if someone knows or has measured the nominal dimension of a new flywheel, that would be very helpful.
Old Mar 26, 2009 | 03:38 AM
chris_barry's Avatar
Its probably worth posting the answer here for other people.
I was also looking for this info and got some answers through PM's and by chance from the exedy australia web site.
Answer seems to be 0.065" to 0.068" or 1.7mm.
Exedy clutch specsheet honda S2000
Chris
Old Mar 26, 2009 | 05:54 AM
SpitfireS's Avatar
chris_barry Posted on Mar 26 2009, 01:38 PM
Its 1.7 mm on my used OEM flywheel.
How to get the dowel pins out though?
You can't press them out from the other side.
They are
Old Mar 26, 2009 | 01:38 PM
The flywheel I had resurfaced had holes through the flywheel so it was easy to knock them out.
Otherwise, you can get dowel pullers. They are basically a slide hammer with a collet chuck on the end.
Alternatively, clamp the dowel in a bench vice leaving a small space between the flywheel and jaws. Then get a big screwdriver and hammer it as a wedge between the flywheel and vice jaws. This last method can damage the dowels slightly so is normally a last resort.
Old Mar 26, 2009 | 03:36 PM
S2KPUDDYDAD's Avatar
[QUOTE=Jreyenga,Mar 18 2009, 10:49 AM]
The flywheel looks like it
Needsmorepower!
Dec 30, 2014 06:56 AM
ssms2k
Jul 18, 2014 03:35 PM
SoCalIsMyLife
Jan 15, 2008 07:35 PM
