forced induction on the s2000
Old Nov 9, 2004 | 03:27 PM
sodaking663rd's Avatar
Default forced induction on the s2000
the s2000 has a high compression engine. i've read in the past that forced induction motors are either better or safer with low compression engines. does anyone have any feedback on this?
Old Nov 9, 2004 | 03:53 PM
kane.s2k's Avatar
Yes
Old Nov 9, 2004 | 03:57 PM
adam_gipson's Avatar
What he means is that yes its true, but he'd prefer you to have searched and found the answer yourself
Slows2k's Avatar
It all depends how much boost is in question, and how detonation resistant the fuel you are using is.
There are plenty of stock motor S2k's running 7.5 psi with a Supercharger, on pump gas.
Both of the superchargers available have pretty good reliability records with stock compression, but they are only at Max boost at max RPM.
If you are running a more boost along with higher cylinder pressures and temps, then it's time to start looking at lowering the compression ratio.
s2kseven
Oct 13, 2013 09:10 AM
abv
Jun 1, 2007 01:43 PM
passmans2kny
Jul 5, 2006 05:31 AM
Iceman1
Nov 23, 2005 07:48 AM
nsxinsac
Nov 8, 2005 12:38 AM
