question about compression
Old Jun 30, 2006 | 01:18 PM
passmans2kny's Avatar
Default question about compression
if i net 330 to 350 hp with a lovefab gt1 kit on stock 11 to 1 compression at 7 psi, what numbers can i expect with 9 to 1 compression at the same boost?
Old Jun 30, 2006 | 04:51 PM
CourageOO7's Avatar
I think most of us would recommend running a thicker head gasket at anything above 7-8 psi...
just a thought...
Old Jun 30, 2006 | 05:00 PM
kane.s2k's Avatar
Around 15hp less
Old Jun 30, 2006 | 07:43 PM
i wasnt sayin nething about raising boost, 15 less ok thanks
Old Jul 1, 2006 | 06:39 PM
spoiled@21's Avatar
really only that much? I would have thought it more. 15hp is well worth the longevity the decreased compression will provide.
Old Jul 1, 2006 | 10:51 PM
9 to 1 compression plus the forged internals, ill motor
Old Jul 3, 2006 | 10:17 AM
Spoolin's Avatar
For every point drop in compression, you will average a loss of around 30 whp at the same psi of boost.
So, if you are making 350 whp on 7 psi with 11:1 compression, you'll drop to around 290 whp on 7 psi with 9:1 compression.
I am going to just be adding headstuds and leaving the compression at 11:1 and running around 10 psi on pump gas. The engine will be just fine there with a good tune.
Remember, 11:1 compression on 10psi is about the same as 9:1 compression on 16 psi and you will net roughly the same peak whp. It's just that doing it on 10 psi and 11:1 compression will yield higher torque down low.
Old Jul 3, 2006 | 07:59 PM
11 to 1 compression at 10 psi wont hurt the motor?
Old Jul 3, 2006 | 08:24 PM
Nick32's Avatar
with a good tune you should be fine.. for awhile at least
Old Jul 4, 2006 | 10:08 AM
yea for a while, i dont have the luxury of being able to blow my motor, i need safe turboness, even though that doesnt exist
