Found leaking hose
Old May 20, 2005 | 10:40 AM
Hamiy's Avatar
Default Found leaking hose
Found a leaking hose, right next to the headers. If you bend down and look straight into the engine, you can see it right next to them with an opening at the bottom leaking what looks to be water or coolant. Not sure though.
I couldn't see anything it would possibly connect to that was close, but there shouldn't be anything leaking.
I don't have a helm manual quite yet so I have no clue what it is.
Also, any chance this is hurting performance?
Old May 20, 2005 | 10:58 AM
C6400hp's Avatar
AC drain?
Old May 20, 2005 | 11:07 AM
Hamiy's Avatar
So it shouldn't be connected to anything?
Old May 20, 2005 | 01:56 PM
xviper's Avatar
Move the car off the spot. Reach down and touch it. If it's water, it will be clear - no need to worry. It's most likely A/C condensation.
If it's coolant, it will be greenish and feel slippery. Worry.
Old May 21, 2005 | 06:45 PM
Squeezer's Avatar
if it comes out of the firewall and points down to the ground, thats the drain line for the a/c evaporator core. nothing to worry about at all. its supposed to drain to the ground.
nguyen365
Jun 17, 2017 10:20 PM
Top_down
Aug 9, 2014 11:34 PM
killerbee_vr6
Feb 15, 2014 07:09 AM
Scot
Feb 22, 2004 06:55 AM
supernig
Feb 10, 2002 04:16 PM
