found this in my differential fluid
Old Apr 2, 2012 | 03:20 PM
ghostsnake's Avatar
Default found this in my differential fluid
Do I need a differential?
I've recently been noticing my car pulls to the right on throttle. I swap the back wheels and it pulls to the left. So I've been trying to play with pressures, but just said screw it and ordered new tires.
Now today I changed my diff fluid and found this piece of metal.
What do u guys think?
Old Apr 2, 2012 | 03:28 PM
itsnoe30's Avatar
https://www.s2ki.com/s2000/topic/515...chunk-in-diff/
familiar thread is familiar. Seems to be that you have nothing to worry about.
Old Apr 2, 2012 | 03:37 PM
ghostsnake's Avatar
I'm going to the track in 2 weeks, so it should be fine right?
Old Apr 2, 2012 | 03:43 PM
itsnoe30's Avatar
I was going to say probably, but Ben's last post has me wondering now
Originally Posted by S2KPUDDYDAD
There are 4 washers inside the factory LSD one at each end and two in the middle. The 2 on each end are locked into the housing and the 2 center that lock into the 8 planetary gears. The little ears of these washers are what you guys are finding. The little ears are what keeps things in place.....if the little ears break off it will allow the washers to spin. This will affect the locking of the LSD as well as cause friction (heat) of the free spinning washer(s) inside the LSD.
Unfortunately Honda does not sell replacement parts for the LSD, the LSD is sold as a unit. I do have many good LSD washers in stock i remove from damaged units that I use to fix this issue when I come across it.
If you only find one ear and the car is just used for pleasure driving (Daily use) you should be fine. If you find 2 or more you will want to replace the washers or replace the LSD it's self. If you find one or more ears and the car is used on the track you will want to repair or replace the LSD ASAP.
Old Apr 2, 2012 | 05:56 PM
S2KPUDDYDAD's Avatar
If the car still feels unsettled with the new tires installed, I would not be tracking the car until you fix what ever issue you have. You could have another problem with the car or the LSD is not working as it should anymore.
Old Apr 2, 2012 | 06:27 PM
japhethwar's Avatar
At first I thought Holy Shit how did a dime get in there. May wanna listen to the diffy man, random metal chunks are never good.
Old Apr 3, 2012 | 12:09 AM
S2K-F8's Avatar
Esactly what I thought when I first saw the pic!
Old Apr 3, 2012 | 03:23 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Dude I just laughed for a minute straight you just made my day
Old Apr 3, 2012 | 03:27 AM
Billman250's Avatar
Top Answer: 1
Oh yeah right...the topic.
I have found those half-moon pieces before with no ill effects to the dif.
As far as your pull, it is 100% without question the tires causing it.
Pressure, brand, size, age, and wear must be an exact match on the rear or the car will pull on acceleration, and shift in the oppositite direction on decel.
My customer that had that ear on his drain plug is going to the draogn with me next week. I'm going to thrash his car left and right turns and see if the dif is acting up at all. As of now it shows no issues.
Old Apr 3, 2012 | 03:34 AM
starchland's Avatar
are you guys finding this stuck to the magnet?
