found this in my differential fluid
Old Apr 3, 2012 | 03:36 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Yes it winds up on the magnet. Great reason to change your dif fluid and clean your magnet. If there is enough metal paste on the magnet, it wont be able to catch big stuff like this and it can do more damage.
I'll post it here too...you can buy a second magnetic drain plug from Honda, and use it in the fill hole and run dual magnets.
Old Apr 3, 2012 | 03:57 AM
starchland's Avatar
cool, well that gives me a little piece of mind knowing it can attach itself somewhere.
Old Apr 3, 2012 | 02:09 PM
Blindeye_03's Avatar
Originally Posted by Billman250
Oh yeah right...the topic.
I have found those half-moon pieces before with no ill effects to the dif.
As far as your pull, it is 100% without question the tires causing it.
Pressure, brand, size, age, and wear must be an exact match on the rear or the car will pull on acceleration, and shift in the oppositite direction on decel.
My customer that had that ear on his drain plug is going to the draogn with me next week. I'm going to thrash his car left and right turns and see if the dif is acting up at all. As of now it shows no issues.
I am used to seeing the tpms light go off sometimes after work due to one of my tires having a slow leak. Well I never got it fixed and after leaving work saw the light go off and noticed that on throttle I had to counter steer and then I had to do the same thing when slowing down. Ended up being that tire w/ the slow leak that now had a fast leak .
Old Apr 3, 2012 | 10:56 PM
s2000maniac's Avatar
so the drain plug is the same size as the fill plug?
Old Apr 4, 2012 | 06:00 AM
dwight's Avatar
Yes. My were installed with the fill and drain it each other's locations when I got my car.
Old Apr 4, 2012 | 05:57 PM
Kool
jst2878
Mar 7, 2018 08:20 AM
pers785
Dec 8, 2015 04:26 PM
allstar71
Apr 26, 2011 01:10 AM
craig2teg
21
Jan 23, 2009 08:05 PM
jski7
Jan 6, 2006 01:07 PM
