Front jacking point
Old Jun 2, 2013 | 10:10 PM
loaferz's Avatar
Default Front jacking point
So in this previous thread, Billman talks about the front jacking point being deceiving and looking like there's "two jack points", I didn't find much clarification on any of the other threads (at least not with pictures that still worked), so I thought I would take some to clarify.
Alright, here we go under the front of the car, I'm assuming from the service diagrams that the area in red is where the jacking point is
Now a closer look, are the "two jacking points" the two different folds here in the metal and that the correct one is the "rear" red highlighted one? Or would it be more secure to use the blue area to jack the front from (which seems to be part of the engine/trans, which I guess would be another hard spot analogous to the diff on the rear jacking point).
thanks
Old Jun 2, 2013 | 10:26 PM
s-nisen's Avatar
Just as pictured in the service manual, the red and green area is the spot. The blue area is the oil pan. Don't use that.
Old Jun 2, 2013 | 10:33 PM
s2cho's Avatar
^ can rip your motor mounts clean off if you jack from the oil pan!
Old Jun 3, 2013 | 06:07 AM
Saki GT's Avatar
From the FAQ in S2k Talk:
https://www.s2ki.com/s2000/topic/753...g-in-s2k-talk/
Old Jun 3, 2013 | 06:19 AM
Bugsy's Avatar
Last pic, bottom shows B. When some people jack the car, they make the mistake of putting the jack under the fender flange. The lift flange the one to the rear.
Old Jun 3, 2013 | 01:58 PM
loaferz's Avatar
thanks everyone
fastD
Mar 24, 2011 02:07 PM
Tadashi
Nov 13, 2007 03:35 AM
AdrianG
Feb 29, 2004 08:52 PM
usdm1
Nov 23, 2003 03:39 PM
