Front Upper Control Arm bolt STRIPPED
For some reason when i was torquing those size 17mm with 75lbs of torque, it didnt hold pretty good and i happen to stripped the nut but not the bolt. Ive tried to rethread them but didnt help at all so what i did was I went to some hardware store and picked up same size of bolt but longer where it can pass through the nut and got myself some wheel stud to hold them for now. They held up pretty good and i happen to torque them at the spec but my concern is, is this good enough? Pls let m eknow any suggestions you guyst might have for me to fix this problem. More feedback, the better thanks much
its rated #10 and heat treated. I hope they are ok, i have been driving it like crazy today and checked them earlier but they seem to be staying where they are..but then again i will definitely look for an oem bolt just to be on safe side. I just hope that they will not snap on me while driving..more feedback pls
if any of you guys currently worked at the body shop or used to work for the body shop, how much do u think will this cost me if i will have them remove that stripped bolt and welded a new one? thanks much
Originally Posted by cdelena,Mar 27 2006, 07:01 AM
Sounds like the bolt strength is ok, if it has the right fit just leave it as is.
s2000maniac
Mar 10, 2014 03:09 PM
