Fuel
Old Apr 25, 2004 | 03:03 AM
bhav's Avatar
Default Fuel
guys,
had my s2k a few weeks now so im kind of new to all this.
Is it important to use high octane fuel i.e. Shell Optimax etc.
and if so whats the difference between this and regular unleaded feul.
Thanks
Old Apr 25, 2004 | 04:02 AM
bhav's Avatar
...does the s2k have a knock sensor?
Old Apr 25, 2004 | 06:51 AM
Clayman's Avatar
Yes, it's important to use premium fuel. You can use regular gas, but the engine will retard timing - causing you to lose power (yes, the car has a knock sensor). It's best to use at least 91 octane. Around here I always use 93, and when it's cheap enough, 94 from Sunoco.
Old Apr 25, 2004 | 07:05 AM
bhav's Avatar
can i go from using regular gas to using 98 octane...will it alter the tuning of the car?
Old Apr 25, 2004 | 07:40 AM
Sideways's Avatar
It will run better with the 98. No need to tune anything, just drive.
Old Apr 25, 2004 | 08:42 AM
BenR's Avatar
Std pump fuel in the UK is 95RON and there area few true 97's, and some hyped up 98's.
Dependant on the engine characteristics of the burn, it might respond well to a higher octane, or it might not make any real difference as i've seen with many other production performance engines, however none, obviously, make the same bhp/ltr output.
And the F20C does have alot of machining marks in the Combustion chamber.
Try and see, its your choice.
Old Apr 25, 2004 | 09:26 AM
bhav's Avatar
handbook reccomends 98
tunermt
Feb 5, 2018 02:26 AM
s57_s2k
Feb 23, 2009 12:56 AM
Jwslick
Feb 21, 2009 01:28 PM
drotoscope
Sep 28, 2007 09:11 AM
Blackie
41
Dec 13, 2003 04:36 PM
