Fuel additives or cleaners
Old Sep 20, 2010 | 09:12 PM
13darkknight's Avatar
Default Fuel additives or cleaners
I always hang out in the automobile section of target/walmart, and always see the fuel cleaners and other liquid bottles they sell.
Does anyone use them? I never for any of my cars before, let alone my s2k.
Old Sep 21, 2010 | 02:29 AM
ifly1956's Avatar
I've only ever used one additive.
I use 1/2 a can of SeaFoam in my gas tank about every 10th fill-up. I first started using it in my outboards years ago, and then in my ultralight's 2 cycle aircraft engine. When I hit 100,000 miles I added some for the first time to the oil. I didn't notice any difference, but since I've only used Mobile-1, I didn't expect to have any sticking rings. I pulled the plugs at 100,000 miles and ran a borascope(?) in each cylinder - no carbon residue on the top an any of the pistons.
Some might call it snake oil, but in both 2 cycle engines I've never had any carbon issues or sticking rings. My ultralight engine now has over 500 hours on it with no issues. The manufacturer says the engine needs a rebuild at 300 hrs. My compression is still excellent, and I don't plan to do a rebuild anytime soon.
As always - your results may vary !
Old Sep 21, 2010 | 03:53 AM
zeroptzero's Avatar
I like to run Redline fuel injector cleaner about once a year, it has a good reputation and these cars do get sticky injectors at times, I've seen one on a set of low mileage injectors that I purchased recently. I like to use an upper cylinder lube like Lucas.
Old Sep 21, 2010 | 08:34 AM
redlineracing's Avatar
I run either BG44K or Redline SL-1 in all my cars about once every 6 mos.The BG is found usually online or at dealerships and is pricey,and Redline I usually find at the Boys of Pep>>
IMO,both do a good job.
\rlr
Carolina
Old Sep 21, 2010 | 12:35 PM
NoRegrets78's Avatar
I use Techron in my vehicles every oil change.
Old Sep 22, 2010 | 08:22 AM
scareyourpassenger's Avatar
bg44k does a great job!
Old Sep 22, 2010 | 08:37 AM
rob-2's Avatar
Same.
After speaking with my chemical engineering friend who used to work at Chevron I'm sold on the product.
Old Sep 22, 2010 | 09:26 AM
w00t692's Avatar
Guess i'll pick up a couple of these and run 1 in a tank of gas for 2 tanks in a row since i have never run it.
When i pulled the injectors they weren't necessarily good looking either lol.
Old Sep 22, 2010 | 09:29 AM
jdmdohcpower's Avatar
Lucus is great
darksparkz's Avatar
+1 on Techron!
