Fuel Feed Hose Leak!
Old Jul 1, 2011 | 12:30 PM
Spnshfirefighter's Avatar
Default Fuel Feed Hose Leak!
My fuel feed hose has a very small "Crack" or "slit" that is allowing a very small leak of fuel to exit. The actual leak is on the rubber hose. (picture below)
Is there any way to temporarily repair a leak on a rubber hose that is going to be holding 35 to 40 psi of pressure?
Can I replace the rubber hose with one identical to it and crimp it down to the original metal fittings?
I've found several dealerships / auto parts stores in the area that have it on back order and it's looking like a 7 to 10 day out kind of process. I need the car over the holiday weekend!!!
Thanks !!!
picture of line - FIXED
http://www.hondapartsunlimited.com/i...nent=FUEL+PIPE
It's #3 on the picture above. If you look at the line directly attached to the "#3" you'll see part I'm speaking of,however the hose or line that's leaking is directly connected, it's directly below the number 3. (the hose is at a 90% angle)
Any help?
Old Jul 1, 2011 | 12:49 PM
robrob's Avatar
Your picture link is broken. Don't screw around with fuel lines. If it splits you can burn your car to the ground in a hurry. Oh, and you might get scorched too. Seriously, don't drive it until it's fixed.
Old Jul 1, 2011 | 12:51 PM
SheDrivesIt's Avatar
Linky no worky.
Old Jul 1, 2011 | 12:56 PM
Fixed link.
Old Jul 1, 2011 | 01:16 PM
robrob's Avatar
No, you won't be able to replace the rubber part and mate it with the stock metal ends. Remember, fire bad.
Rockin S2K
Mar 18, 2018 03:23 PM
MarcS2000
Jul 20, 2015 02:29 AM
Orjinal
Jul 12, 2014 02:31 AM
Deano_d
Apr 24, 2014 02:27 PM
chriss.
Oct 5, 2012 07:42 PM
