Fuel Gauge
I took my car to the track yesterday evening with approximately 80% fuel in my tank, and after four 20 minutes sessions, I called it a night. At that time, my fuel gauge dropped down to about 55% full and I decided to get some gas before making the long haul back home. I filled up the car, thinking it would only need about 5 gallons, but it turns out the car sucked down close to 10 gallons. I'm puzzled as to why my gauge indicated 1/2 full when it was nearly empty.
I haven't had any problems like this before, and the gauge corrected itself on the drive back (it's sitting at 1/2 full after driving 125 miles). Any suggestions on what's going on here?
-Chris
-Chris
I'm pretty sure there is a time delay on the fuel gauge level. otherwise you'd gain/lose bars every time the fuel sloshes around in normal driving. You're sucking a huge amount of fuel during a track day and it just doesn't adjust to it very well.
I thought I gave the car adequate time to recalibrate the sensors. I let the car cool down for 30 minutes after my set and I drove the car to the gas station which was located 5 miles away at moderate speed in 6th gear.
Now I'm worried about running out of fuel on track one of these days...especially if I go on 1/2 full.
I ran out of gas on the track. Well, actually about a mile away from the track.
I got 12mpg on track day so use a lower number to do your math.
I finally had to get 2 gallons of gas from a tow truck using roadside assistance. I've learned my lesson...I'm getting gas during lunch!
I got 12mpg on track day so use a lower number to do your math. I finally had to get 2 gallons of gas from a tow truck using roadside assistance. I've learned my lesson...I'm getting gas during lunch!
mapsi
Oct 16, 2012 03:08 PM
