Fuel injector replacement/aftermarket
Old Feb 27, 2022 | 09:54 AM
bega2001's Avatar
Default Fuel injector replacement/aftermarket
I have an 04 with 183k and about a month ago my check engine started flashing and I found out my first cylinder was misfiring. I went ahead and changed the spark plugs and also got new coil packs. While changing the coil packs I noticed the connector on the first one looked like it was in need of replacing. A day or two after replacing the coil packs it was misfiring again pretty bad. I went a head and ordered new connectors for all four but I was thinking of also replacing my fuel injectors to be safe and since they probably haven’t been replaced even before I bought the car.
Any advice on where I can get good aftermarket injectors?
Old Feb 27, 2022 | 11:40 AM
Slowcrash_101's Avatar
Have you done a valve adjustment?
Fun fact, we use the same injectors as in the 1st gen Hayabusa.
Old Feb 28, 2022 | 09:45 PM
flanders's Avatar
No they are not the same.
They have the same physical dimensions and impedance, but a different flow rate.
Old Mar 1, 2022 | 11:22 AM
Jah2000's Avatar
Aren't TSX injectors of the same generation/year compatible?
tx_s2k
Jun 28, 2018 04:37 PM
austincrx
Aug 2, 2014 10:54 AM
Black Nugget
Sep 29, 2010 01:57 PM
preppyS2000
May 3, 2006 01:28 PM
w1ngman
Nov 15, 2002 09:34 PM
