Fuel Issues
I have heard numerous complaints about Shell V-Power (my guess is just too much detergent). I had a friend put a tankful in his car (Chrysler Conquest) and it ran horribly under boost. Bucking and sputtering like crazy. It was so bad we drained the tank, went and filled it back up with BP Premium and the car ran fine.
I personally always use BP and have never had a single problem with it. I also have the BP Chase credit card which gives me lots of free gas
Originally Posted by Ek9,Aug 31 2006, 06:04 AM
Local car radio show's been mentioning that with Ethanol, the need to fuel dryers has actually increased because ethanol doesn't actually bond with the water in the tank and can actually cause water or pure ethanol to settle out to the bottom of the tank. Recommending monthly application of a fuel dryer.
Moisture will cause mis-fires too.
The key to using this type of fuel is to minimize the chance of fuel tank condensation, which means to keep the tank from getting too low, something that most drivers will be reluctant to do.
I use 10% ethanol gas from time to time, especially in winter to act as a gasline antifreeze, but I may stop doing this as I typically let the gas tank get to near empty before filling up. A proper MeOH based gasline antifreeze additive may be the better way to go even though I've never had any problems to date with 10% gasohol.
If you're around any big city, it's become mandatory all year long. I'm 50 miles from DC and all of our fuel is E10 (10% ethanol). I've never gotton over 20-22 MPG out of my S2000 either.
I tend to agree also that all the fuel's pretty much the same in an area. That's why I tend to use whatever's fuel's close. I've never had a mis-fire code.
Originally Posted by mikegarrison,Aug 31 2006, 10:49 AM
In the US, we generally don't have much of a choice about using ETOH. Up to 10% is legal (and in many places also mandatory, at least some of the year).
"PetroCanada" actually advertise that they put ETOH in the gas as their "winter blend". They don't say how much.
Originally Posted by xviper,Aug 31 2006, 11:54 AM
Does this mean that your fuel manufacturer "can" put anything up to 10% without telling the buying public that it's in there?
Here the labelling is required. Some use ethanol, some don't. It used to be just the cheap brands did it. Now, like I said, I've seen Shell do it as well but it changes by area. Here in Ohio, the fuel requirements change by county based upon air pollution violations.
