Fuel Lines
Old Feb 11, 2005 | 12:21 PM
learnerspermit's Avatar
Default Fuel Lines
Hey Im doing a braided fuel line. Also I am alos going to do the return line. the fittings and such that attach to the fuel line I dont need, but the ones that attach to the fuel filter and where ever I can attach the return line to I do need to know. So if anyone has pictures or part numbers that will help me that would be great.
Thanx
Eric
Old Feb 11, 2005 | 01:43 PM
kane.s2k's Avatar
*ninja edit*
Old Feb 11, 2005 | 03:50 PM
Slows2k's Avatar
Unless you are making 600+hp the stock fuel lines do just fine.
Old Feb 11, 2005 | 04:43 PM
I have looked into getting aanother fuel filter.
Already got the FPR covered.
So In your opinion. Get the fuel filter with AN fitting.
So where can I run the line from the FPR to? Is there anywhere between the tank and the FPR that I can attach the fitting to.
Old Feb 11, 2005 | 07:57 PM
Slows2k's Avatar
There is no EASY way to install an AN braided fuel line. The stock fuel line uses totally different sealing/attachment methods. You are going after a completly un-needed modification.
Unless you plan on buying a $300 AN flaring tool to flare the Stock fuel fine to accept AN flares, find something else to spend your $ on.
Old Apr 29, 2005 | 06:05 AM
darkknight1999's Avatar
Which line can I pull to drain some gas out of the fuel tank??
Old Apr 29, 2005 | 11:57 AM
to drain hmmm i dont know if its the best but take the fuel cap off to release pressure from the system then disconnect the fuel line from the rail and put in in a container and then trun the key over
there maybe a better way though
Z32MadMan
Dec 3, 2016 09:48 AM
schhim
Jun 21, 2015 02:05 PM
MugenAP2
May 20, 2008 01:16 PM
GDM S2K
Mar 15, 2006 01:56 PM
dereks2000
May 17, 2003 06:37 PM
