Fuel Pump
7: Remove the bolts (A) and the fuel tank unit (B). (A) shows 8 bolts in a circle holding the whole unit submerged in the tank. Looks like it just lifts out here.
KEY TIP: Also, before lifting the unit out of the tank get a LOT of towels/rags. As you lift it out you have to tilt the unit over to clear the filter secured to the bottom. When you do this a lot of gas "will" spill. You don't want your car smelling like fuel do you?
