Fuel pump won't prime
Old Mar 30, 2013 | 02:00 PM
jsenclosure's Avatar
Default Fuel pump won't prime
I'm having an issue with an 05 i picked up. Car was previously turbo (900whp) and a lot of the wiring was modified. So i replaced the main interior harness and the fender harness and battery harness to get all the wiring in the car back to oem. i do not have an engine in the car at the moment and no engine wiring harness either. I am swapping in an Ap1 engine so i swapped the ignition and ecu to an ap1 that i got from the same car. Hooked up the battery and the fuel pump will not prime.
i know this fuel pump is good as it came out of a running car i had. The turn signals and top motors work as they should, as well as the trunk light and brake light.
Just to rule out a few things i swapped the fuel pump fuse, twice, and still nothing. I also tried using the 05 ecu and ignition and still nothing. i swapped the main 40amp fuse in the under hood fuse box as well with no luck. i also tried hooking up the engne harness to the ecu and under hood fuse box but again no luck. swapped the PGMFI relay from my 00 and still nothing. i am getting no power to the fuel pump connector when i test it with my multimeter which leads me to believe it is a fuse or realy perhaps.
What am i missing? Thanks in advance
Old Mar 30, 2013 | 02:13 PM
boyguan's Avatar
Check with a multimeter to make sure no break in the wiring
Power up the pump directly with a 9 volt battery to make sure it's working even though you know it's good but could be damaged
Old Mar 30, 2013 | 02:20 PM
i know the pump works, i just replaced the harness and know that is good as well. is there a relay or fuse or something of the like i have missed and can check?
Old Mar 30, 2013 | 03:43 PM
read a bunch of threads, went back out to the garage and swapped over the PGMFI relay from my 00 and still nothing.
Old Mar 30, 2013 | 06:11 PM
boyguan's Avatar
Knowing that it is good without a test is a guess
There is a fuse for the fuel pump and most cars should have a relay but I am not sure about the s.
Did you try to power up the fuel pump at the pump
Old Mar 30, 2013 | 06:45 PM
I took the fuel pump out of another running s2k I have, so I know it's a good pump, it's not a guess
Old Mar 30, 2013 | 06:48 PM
Here is a thought, if the fuel pump float is at the bottom, lowest level, will the pump even turn on? The is very little fuel in the tank. Anyone know this?
Old Mar 30, 2013 | 07:26 PM
boyguan's Avatar
It will run but just burn out after a while
The float and pump have no relation as far as on and off
Old Mar 30, 2013 | 07:35 PM
Hmm, I'm just spitballing, I'm out of ideas
Old Mar 31, 2013 | 04:58 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If there is no engine in the car, temporarily ground the wire that went on the back of the cylinder head to the body.
With the ignition key on, make sure the green immobilizer key light on the dash goes on, then off and does not continue to blink.
