full fluid change
hey guys, i'm trying to find out the amounts of fluid i need for each.....and what other things we need like washers and yada yada...
differential
breaks
tranny
clutch
i'm in need to do all these.. but i'm not sure how much of each of these things i need to purshase, and which ones will need new washers/bolt and the whole works....
thanks in advance for any help...
differential
breaks
tranny
clutch
For the Diff and Tranny I don't think there is a set amount...you just fill it until a steady stream of fluid comes trickling out and cap it as fast as you can to make sure you get the full amount of fluid in there.
The brake and clutch will vary depending on how much air that is needed to be bled from each. But I think getting 4 brake/clutch fluid bottles from Honda should be plenty to do all four brakes and the clutch.
For the Diff...I use Mobil 1 (Forgot the number but Its like 90w-10?)
The Brake and Clutch I just use Honda factory.
datchineseguy
Sep 22, 2006 04:21 PM
