Fluid Changes
Old Dec 26, 2006 | 04:58 AM
fromthegut's Avatar
Default Fluid Changes
Just purchased my car. The car is 2004 and has 5,000 miles.
I changed the oil, oil filter and differential fluid.
I am wonder about the others - transmision, brake and clutch fuids. Yes the milage is low but it has 2 years on them.
Thank you,
Old Dec 26, 2006 | 07:17 AM
S2kracka's Avatar
Might as well do the tranny fluid too. I wouldn't worry about the brake or clutch fluid, although others may tell you I'm wrong.
Old Dec 26, 2006 | 07:19 AM
FISH22's Avatar
wow, 5k miles on an 04!! crazy. yeah, i wouldnt worry about the clutch and brake fluids...but you should change out your tranny oil to the new 07 honda mtf, good stuff!!
oh, and by the way, what did you put in your diff?
Old Dec 26, 2006 | 10:33 AM
fromthegut's Avatar
Service invoice says
HP Gear Oil 80/90
MOC Limited slip additive
MOC Extreme pressure lube
Old Dec 26, 2006 | 11:20 AM
chuhsi's Avatar
I would personally change all fluids and start clean
Old Jan 2, 2007 | 08:43 AM
vtec9's Avatar
5k on an 94 thats nothing.. my '00 only had 7995 miles when I picked it up in december 05 needless to say, it has a shit load more now.
Anyway, personally I would change the tranny fluid at 10k, but it definitely doesn't need it. If you feel like it, use new Honda MTF.. otherwise, save yourself some labor time. basically do whatever you want
shumax
Feb 27, 2012 04:16 AM
llckll
Mar 10, 2011 11:30 AM
johninator
Apr 24, 2004 09:19 AM
ScottB
Mar 26, 2004 08:10 AM
Billman250
Nov 14, 2003 05:27 PM
