FWD conversion?
Old Apr 1, 2005 | 06:14 AM
twohoos's Avatar
Default FWD conversion?
OK, no flames please, I am serious. I am considering a FWD conversion for my S and I want to know if anyone has any experience or tips. The rear drive handling is a liability in wet weather, plus the transmission losses are way too high. So I'm considering either a K20A or F22C swap into the S, driving the front wheels with either an RSX-S or TSX manual tranny. This should save a lot of drivetrain weight as well.
I need tips on:
- Which way should the engine spin, i.e. could an F22 work with other FWD trannies, or do I need to go with the K-series?
- Any tips on mounting the new drivetrain? Can I keep the stock front subframe?
- I know I'll have to replace the front suspension to avoid interferece with the front drive axles. Should I go with MacPherson struts to save space?
- What kind of aftermarket diffs are available for the K-series drivetrains?
Thanks for any help you can provide. I can't wait to pop the hood and see the engine facing the "right way" for a Honda (transverse)!! And with the weight savings I bet I can get into the low 13's for sure.
Old Apr 1, 2005 | 06:32 AM
DiamondDave2005's Avatar
Hmm, April 1st, huh?
Old Apr 1, 2005 | 06:43 AM
Bullitt44's Avatar
I need tips on:
Durrrrrrrrrrrrrr, and I am going to turbo charge my moped!
Either this is an April fools or your sniffin glue buddy!
Old Apr 1, 2005 | 06:44 AM
spessx's Avatar
If you're still interested on April 2nd - just buy an RSX.
-s
Old Apr 1, 2005 | 07:50 AM
xviper's Avatar
I would strongely suggest you find an Olds Toronado. That drivetrain will pop right in, no problem.
Old Apr 1, 2005 | 09:11 AM
S2000RAT's Avatar
Go buy a SRT-4
Old Apr 1, 2005 | 09:48 AM
Chazmo's Avatar
Push down on the stick, push it all the way to the right, shift DOWN. Let up on clutch; press accelerator pedal. Voila.
Old Apr 1, 2005 | 09:57 AM
3ngin33r1's Avatar
better than the other 4/1 stuff I've seen so far.
Old Apr 1, 2005 | 12:22 PM
Asura's Avatar
JMac
Old Apr 1, 2005 | 02:04 PM
twohoos's Avatar
Heh, you guys are too good - I thought *somebody* would bite! Should have posted it in S2K Talk...
"Olds Toronado"
