Gap between the header and test pipe
hi, i just install my Ricks header and t1r 70mm test pipe, is there suppose to be a gap between the head and test pipe. also the test pipe look kinda loose when i bolt everything up tight.
uhm. If you bolt everything up tight but the test pipe is loose, then it's not bolted up tight, is it?
or is there an actual gap between flanges after bolted tight?
If that's the case, one or both of the flanges are warped.
This is a pic of my S before I installed my TP. As you can see, there is a nice gap between the header flange and the cat flange. It was the same after I installed the TP. this is normal. I'm almost certain that the Ricks Header uses a doughnut gasket. It is made to mate up to the stock cat. Hope this helps.
Originally Posted by Stratocaster,Oct 29 2008, 01:02 AM
Yes.
It also ships with a set of gaskets in the box. Check the bottom of the box. hopefully you did not toss it without finding them.
