Gap between the header and test pipe
Old Oct 28, 2008 | 11:55 AM
albe's Avatar
Default Gap between the header and test pipe
hi, i just install my Ricks header and t1r 70mm test pipe, is there suppose to be a gap between the head and test pipe. also the test pipe look kinda loose when i bolt everything up tight.
Old Oct 28, 2008 | 12:05 PM
chimmike's Avatar
uhm. If you bolt everything up tight but the test pipe is loose, then it's not bolted up tight, is it?
or is there an actual gap between flanges after bolted tight?
If that's the case, one or both of the flanges are warped.
Old Oct 28, 2008 | 12:24 PM
2poor2mod's Avatar
or you forgot to install a new donut gasket
Old Oct 28, 2008 | 12:28 PM
chimmike's Avatar
does the ricks header utilize a donut gasket?
Old Oct 28, 2008 | 01:22 PM
Slick2K's Avatar
This is a pic of my S before I installed my TP. As you can see, there is a nice gap between the header flange and the cat flange. It was the same after I installed the TP. this is normal. I'm almost certain that the Ricks Header uses a doughnut gasket. It is made to mate up to the stock cat. Hope this helps.
Old Oct 28, 2008 | 03:52 PM
EVAN&MONICA's Avatar
Old Oct 28, 2008 | 10:58 PM
albe's Avatar
i used to stock Cat Gasket. will it be fine?
Old Oct 28, 2008 | 11:02 PM
Stratocaster's Avatar
Yes.
It also ships with a set of gaskets in the box. Check the bottom of the box. hopefully you did not toss it without finding them.
Old Oct 29, 2008 | 03:54 AM
slipstream444's Avatar
Originally Posted by Stratocaster,Oct 29 2008, 01:02 AM
Yes.
I had mine sent off from Rick's to HPC for coating and it didn't show up with any gaskets - I had to purchase them separately.
Old Oct 29, 2008 | 08:32 PM
a_zepeda926's Avatar
there is supposed to be a gap. i would double check for leaks, as i had a problem with that, and ended up having to ditch the stock type spring loaded bolts, for something else.
