gauge cluster light problem...
Old Jul 10, 2007 | 12:54 PM
cubide's Avatar
Default gauge cluster light problem...
hi, today on the way to work, i noticed the gas indicator light wasnt on, but the rest of the cluster was lit up. for example the temperature gauge was lit up and the rpm was also lit up, but not the gas indicator. it seems as if the right side of the cluster went out. my question is are there light bulbs i can replace it with or any fuses i can replace? i looked for fuses but didnt see anything, or do i just need a new cluster? plz help, much appreciated, jimmy.
Old Jul 10, 2007 | 12:57 PM
nightcrawler7188's Avatar
shouldn't be any bulbs to replace...
Old Jul 12, 2007 | 06:56 AM
MacGyver's Avatar
Dude, what are you smokin'
Yes, there are incandescent bulbs behind the cluster... about 5 on the AP1s, don't know about the AP2s, but probably similar. The bulb for that section most likely burned out or is loose. To get to it you'll need to drop the steering column and remove the cluster trim... not a hard job, but can be a bit time-consuming.
Old Jul 12, 2007 | 08:48 AM
^^ah i was thinking the whole cluster was like the tach/speedo. i guess not!
Old Jul 12, 2007 | 09:14 AM
MacGyver's Avatar
You do realize the entire cluster is lit from behind by bulbs, including the tach/speedo, right?
Old Jul 12, 2007 | 09:46 AM
i feel dumb. i thought the tach/speedo was lcd. if i ever need help with anything electrical i'll be sure to contact mr. master's in electrical engineering!
Old Jul 12, 2007 | 10:21 AM
MacGyver's Avatar
It is LCD... but it's backlit by bulbs.
Old Jul 14, 2007 | 02:20 PM
cubide's Avatar
thanks mac, your a big help.
SRap1
Sep 17, 2011 02:47 PM
apkarian100
May 11, 2009 06:45 AM
sbrodacz
May 10, 2008 09:20 PM
cubide
Jul 6, 2007 12:29 PM
cubide
Jul 6, 2007 11:40 AM
