Gearbox first gear
It's not noisy
Ok so engine off and cold, all gears pass smooth.
But when i drive the car, for exemple i arrive at a red light => down shift, down shift and when i'm slow in 2nd, I put the first gear when i'm at 0, it's at this moment. When the first gear is half engaged, it feels like a little struggle and if i finish to engage the first gear I feel that I push something in the gearbox
When engaging first gear when the car isn't moving you will usually feel a slight "clunk". This is normal, and is quite noticeable when the engine is cold.
If you're having trouble downshifting into first when coasting to a stop, try double clutching (put it in neutral, take your foot off the clutch, then press on the clutch pedal and put it into first). But don't try to put it in gear if you're still rolling.
