Gearing question
Old Apr 8, 2006 | 11:28 AM
  #41
PilotSi's Avatar
[QUOTE=xviper,Apr 8 2006, 09:50 AM] Just as you are a mechanic and have free dyno access.
Old Apr 8, 2006 | 12:36 PM
  #42
xviper's Avatar
Originally Posted by PilotSi,Apr 8 2006, 12:28 PM
Anyways -- so if me & the OP both have 4.57s, but we're revving high on the hwy (and him on the track)...what gives? I have stock sized tires, and they're inflated to the recommended pressures of 35psi. What else would cause this shorter gear ratio?
That's the only variable I can come up with - tires. But ~-1" difference on stock rim/tires? (referencing xviper's number from earlier)
First of all, one shouldn't be comparing rpm to the mph you see on the instrument panel UNLESS you are absolutely sure the correction factor in the speed compensator is precise. You wouldn't really know what your mph is for true.
Let's say there is a discrepancy in tire diameter. A difference of 0.7" would introduce an error of about 3% to the speedo.
Old Apr 8, 2006 | 09:18 PM
  #43
twohoos's Avatar
The rpm on the stock tach is also an error source. For example, mine reads about 100rpm higher than the display on my VAFC; not sure which is closer, but obviously there's room for error there too.
Crayon, guys, crayon.
JPRICE!
Jan 23, 2011 03:22 PM
RayRay
Mar 18, 2009 08:19 AM
attack666
Aug 26, 2007 03:50 PM
simons2k
Jan 3, 2004 10:49 AM
krazik
Jan 21, 2001 09:52 PM
