Gears 1-4 and Reverse work No 5th 6th
So i bought a s2k oem everything 131 k comes up i started slippin so i did the clutch today i finished and was putting the shifter back in (This was the first thing I tool off) and i started goig through the gears and couldnt get into 5th and 6th at all but I can get into reverse perfectly . When i try to go into 5th and 6th it feels like a wall is there and im completley blocked off. I took the shifter out and stuck a 3/8th extention down there and again tried to go through the gears and same results. pleae help
yeah but i took the shifter out and put in a 3/8th extention to see if it was just my shifter and when i try to go in 5th it wont work. By shifter you mean the actual shift stick it only fits one way because theres a small grove in the center
& 6th but i got play going towards 1st 2nd
