problems after trackday
Old Sep 26, 2017 | 02:39 AM
Ajolote's Avatar
Default problems after trackday
Hi, everyone, after the last 2 trackdays i have problems in the gear box.
The 1st time i couldn´t put the 6th gear ( but in the track i dont use it, only until the 5), and trying and forcing i little bit finally i could put the 6th and works well then. But in the 2nd time, the 6th enter so difficult, and it is almost impossible to remove it, It´s very hard to put neutral. I change the oil to Redline MT90, maybe this is the problem?, because other trackdays few months ago i had no problems.
regards
Old Sep 26, 2017 | 04:31 AM
cdelena's Avatar
Sometimes a ragged shift into third at high rpm will clip fifth affecting the sleeve which is also is needed to shift into sixth. Repeated forcing the shift between 5 and 6 can clear some damage and restore operation. A fluid change afterwards is prudent.
Old Sep 26, 2017 | 07:07 AM
bgoetz's Avatar
Did you ever miss your 2/3 upshift and hit 5th? If so that is your problem, you put a bur on the gears. I had the same issue and you have to run to 7k in 5th, drop to 6k, back to 7k and keep repeating a few times. Then with the car parked and off, clutch in shift between 5th and 6th 100 times. This should clean the gears.
Old Sep 26, 2017 | 07:30 AM
RussianHammer's Avatar
Top Answer: 1
your clutch maybe going out. Set some money aside for that.
I had a track day, and blew a spring. this did not let me change gears.
Old Sep 26, 2017 | 08:08 AM
Ajolote's Avatar
but only happens in 6th, the others gear enter perfectly
Old Sep 26, 2017 | 10:29 AM
bgoetz's Avatar
Again did you ever miss 3rd on an upshift and grab 5th?
Old Sep 26, 2017 | 11:37 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Guaranteed.
Old Sep 28, 2017 | 03:44 AM
Ajolote's Avatar
that case would say that has never happened to me
Old Sep 28, 2017 | 09:42 AM
bgoetz's Avatar
i would still try that fix, it still sounds like you burred 5th for whatever reason.
Old Sep 28, 2017 | 10:26 AM
s2000maniac's Avatar
I’m guessing this would be safer to do while the car is on 4 jack stands. 7k in 5th gear for AP1 is over 100mph
