Gears Questions
Old Sep 17, 2006 | 09:51 PM
s2krazy01's Avatar
Default Gears Questions
Would gears decrease 0-60 times?
Also, my car makes a faint whine as it accelerates and is at ~4k rpm at 80mph in 6th. I bought it used and would like to know if I may unknowingly have gears installed.
Old Sep 17, 2006 | 09:58 PM
Sideways's Avatar
Maybe, maybe not. Get them too low and you have to shift twice before 60 mph. What is so magic about 60 mph?
Old Sep 17, 2006 | 10:01 PM
SilverKnight's Avatar
Don't worry s2k geared > non gear s2k.
Yes you will have a faint whine at first but it will go down after 500miles. Mine actually dind't even have a whine at all for current set of 4.57s. When I had 4.56 there was a whine which went away.
Old Sep 17, 2006 | 10:08 PM
s2krazy01's Avatar
Just wondering about the 0-60 and if gears could achieve sub 5.0
And for clarification, I have not installed gears myself, but would like to know if, based on my description, I have them already.
Old Sep 17, 2006 | 10:16 PM
stock non geared with a good launch you can be at 5.2 if your worried about 0-60. I think it was in 2000 when MT did a test on a MY00.
If you truly want fast 0-60 get a SC and be in the 4s.
Old Sep 18, 2006 | 10:57 AM
s2krazy01's Avatar
does anyone recall what rpm a stock s2000 is at in 6th going 80?
thanks silverknight, i know what a stock s2000 does but i was just curious if gears would bring one into the 4's. i'm not worried about it and there's nothing "magical" about 60, just wondering.
Old Sep 18, 2006 | 11:23 AM
RED MX5's Avatar
Here's a graph showing the speed vs RPM in each gear for a stock AP1.
Old Sep 20, 2006 | 02:03 PM
xviper's Avatar
If you unknowingly have "gears" but the previous owner didn't bother to put on a speed compensator (Yellow Box), no graph will help you as you will still read the same rpm for any designated road speed. The only way to find out is to get paced by another car or by GPS. When the known source is going at XX mph, note your rpm and what gear you're in. Then, look at the graph to see how it compares.
Old Sep 20, 2006 | 03:31 PM
RED MX5's Avatar
Good point XViper.
Now I feel stoopid.
Old Sep 20, 2006 | 04:49 PM
xviper's Avatar
Originally Posted by RED MX5,Sep 20 2006, 05:31 PM
Good point XViper.
Now I feel stoopid.
You shouldn't feel that way. Now he has something to refer to once he gets those numbers.
(You watch my back. I'll watch yours. )
