Is this going to be an issue?
Old Jan 28, 2015 | 12:46 PM
gpep77's Avatar
Default Is this going to be an issue?
So I just installed a password JDM front strut bar on my S2000. Yes...I know this bar does little to nothing for performance, BUT I picked it up used (for an absolute steal) off of a local S2000 owner. I was reading online and read somewhere this bar was supposed to come with a cruise control bracket, but I did not get one. And I have contacted PWJDM to try and buy one, but have not heard back from them. I ran the cruise control line underneath the bar. It is barely touching, but it is touching. It does not look like the line is kinked in any way, but I just wanted to verify this is not going to a problem. Or that this will not damage the cruise control in the long run. I first tried to run the line through the holes in the bar, but it looked like it was creating more pressure that way, and I didn't like the idea of running it through the bar. The cruise control works fine while driving, and the throttle is working normally too. Anyways...pictures to follow. Let me know what you guys think!
Thanks
Old Feb 1, 2015 | 05:03 PM
Utah S2K's Avatar
Shouldn't be but you can call PWJDM and ask to speak with Brad. He can tell you for sure and get you the part if needed.
Utah
Old Feb 1, 2015 | 05:17 PM
zeroptzero's Avatar
It won't affect anything, to reduce a wear spot on the cable you can put a small piece of rubber hose around the cable in the contact spot. Did you try running it above the bar ?
Old Feb 1, 2015 | 06:51 PM
Vanishing Point's Avatar
+1 on the rubber sleeve over the cable making contact if you are concerned about wear.
CapoArgentino
Aug 17, 2010 08:48 AM
1_slow_s2000
Dec 25, 2009 10:45 AM
MisterMonkey26
Jun 18, 2009 05:06 AM
3312DC
Aug 12, 2005 05:55 AM
