Got a CEL Code!
Old Jun 5, 2004 | 04:54 AM
Salaska's Avatar
Default Got a CEL Code!
Hi,
after some slow driving i got a CEL Code today.
My ODB-II Software says:
Category: Powertrain
Description: O2 Sensor Circuit High Voltage
What does that mean and how can i fix it?
Old Jun 5, 2004 | 06:52 AM
Salaska's Avatar
BTW: It seems the CEL Code means the 2nd O2 Sensor (in catalytic converter).
Hopefully it does not mean that my cat is defective
Old Jun 5, 2004 | 08:12 AM
Slows2k's Avatar
Most likely it's a bad 02. Does your OBDII software let you monitor the 02's output voltage? If the 02's output Voltage stays above .6V, and doesn't switch from .1-.9V at idle, it's a bad 02.
The sensor is pretty expensive, you could replace the cat with a straight pipe and 02 simulator and spend less than the 02. That is if your emmisions control laws allow that sort of thing. It is illegal here in several states, but emmision checks and reguations vary state to state.
Old Jun 5, 2004 | 08:17 AM
Salaska's Avatar
I use Digimoto 3.7 and it allows monitor the O2 voltage. I will check this later and tell you what it shows.
Thanks for your helping, Chris
Old Jun 5, 2004 | 10:14 AM
Salaska's Avatar
I just checked it.
The voltage from the 2nd O2 Sensor stays always on 1.25V and dont go up and down
Could this also be possible because of the vtecfrog harness i have (pins not connected)?
Old Jun 5, 2004 | 12:24 PM
Slows2k's Avatar
If you have a voltage input to the pcm, most likely your wiring is good. Does your PLX tap into the primary or secondary 02?
If you want to check Vtec frog harness, unplug it and re check your 02 volts. Same result, it's a dead 02.
Old Jun 5, 2004 | 12:56 PM
Salaska's Avatar
The PLX tap into the primary O2 and the primary 02 heater circuit.
Is the primary and the secondary O2 identical?
If so i could install my old primary O2 for the defective secondary O2. Because i use now a Bosch Lambda Sensor for the Primary O2.
Old Jun 5, 2004 | 01:00 PM
Slows2k's Avatar
Can't swap the 02's they have different heater elements.
hocuspocus
Apr 22, 2015 05:50 PM
zeroptzero
Jan 24, 2010 02:46 PM
Brian Si
Jan 3, 2010 07:31 PM
thats_mr_2_u
Dec 29, 2006 10:46 AM
wildcardtrd
Jun 21, 2006 06:02 AM
