Got my code the correct way....Thoughts?
Old Jun 28, 2006 | 05:52 PM
fuzy24's Avatar
Default Got my code the correct way....Thoughts?
Pulled my code with the tool from Advance Auto today...gave me the PO172 System Too Rich (Bank 1) code.
02 sensor? Anyone had any experience with this one or know specific fixes they've done?
Old Jun 28, 2006 | 06:57 PM
Slows2k's Avatar
Fuel metering DTC's can be difficult to diagnose when you can read the data list on a scan tool. Anything I can reccomend would be a guess, and you'd be most likely wasting $$$ changing parts.
I'd look for a good technician that can read OBDII data stream.
Old Jun 28, 2006 | 08:39 PM
Utah S2K's Avatar
There are several areas to look at depending on if you have modded the cars fuel/intake system:
1) Fuel pressure-Too high or too low will throw this code
2) Bad Primary O2 sensor (HO2S)
Note: Normally this failure will also throw a P0135 first
3) Loose valve clearance
4) Bad fuel injectors (or wrong size)
5) EVAP canister purge valve.
If you or anyone else has messed with one of the noted areas I would check there first. If not then I would concur with Slow. If you take it to the dealer then you won't buy a bunch of "test parts" during your troubleshoot.
Utah
PrimePowerPro
May 28, 2015 07:12 PM
airintake0_0
Aug 16, 2013 11:19 AM
s2konroids
Apr 29, 2010 01:54 AM
Artisan7471
Sep 27, 2006 08:54 PM
LeonGalt
Jul 26, 2006 06:33 PM
