The greddy emanage chronicles
Good question, but this seems more time consuming and pricey than actually utilizing perhaps a J&S knock sensor that can retard timing per cylinder when it detects knock. I am unsure if they have an application for the s2k but its very possible. This coupled with an emanage could work great
I have a mugen exhaust and do not plan to take it off. Ultimate racing made a 2 way downpipe that would let me keep the mugen exhaust while running a turbo setup. What do you think about this?
http://www.ultimate-racing.com/Products/El...wnPipe-US.shtml
I am unfamiliar with the mugen exhaust and its ID dimensions or how restrictive it is. From the looks of the UR 2 way down pipe it looks very clever. Theoreticaly it should work great since essentially you are running an open downpipe that creates minimal backpressure and thats great for turbo apps
Terry the coils and wires are not time consuming and not really that pricey. GM coils are cheap, I don't know what wires you would use, but this is the same set up that Electromotive uses.
I have the J&S which is currently uninstalled and I am almost positive it will not pull timing from individual cylinders, but from all at once.
Pulling a cylinder at a time would seem to require 4 knock sensors and the J&S only utilizes one. I will pull the manual out tonight and confirm.
The problem with using the J&S as anything but a safeguard is that it pulls too much timing, or at least that is the most common complaint on other platforms. It is meant to be a safeguard, not your prime timing retard or control.
Do you use the Profec boost controller to manage the eManage? If not why not? Being able to manage the map from inside the car without a computer would seem to be a big plus.
You mentioned that the maps you are making wouldn't work on another turbo. Forgive me for my ignorance, but as far as the boost goes doesn't it simply read boost, regardless of rpm, and enrichens to match?
I know you said it doesn't have a temp sensor which could be a very big knock issue with our CR, but has anyone figured out a way to integrate a temp sensor?
The Dodge SRT 4 utilizes a temp sensor on the IC, when the temps exceed X coming out of the IC it cuts boost. Very cool concept, I wonder if there is a boost sensor that could utilize this feature and in a way give us back a temp compensation.
I have the J&S which is currently uninstalled and I am almost positive it will not pull timing from individual cylinders, but from all at once. Pulling a cylinder at a time would seem to require 4 knock sensors and the J&S only utilizes one. I will pull the manual out tonight and confirm.
Could you find out if it has the capabilities to retard per cylinder.
I am unware of a boost sensitive boost controller that would retard boost, I am pretty sure it does not exist....but I could be wrong
So the cat HAS to be removed? If not has the set up been tested with the cat? Was the restirction in the stock exhaust piping (only 2 1/2 inch), in the resionator, the cat, or mufflers? Stock exhaust looks pretty damn straight, I don't see where bending would cause a restriction (Now I had an 88 Camaro, you want to talk about restiction in the exhaust!).
