Ground wire system
Old Mar 17, 2006 | 01:34 AM
REVZ TO9's Avatar
Banned
Default Ground wire system
How come when I tried installing a ground wire system/voltage stabalizer, my battery sparked at the end when I applied that spiral disk holding all the wires? I could have sworn I grounded all the wires in all the correct 5 places, like the directions said. My friend said it replaces wither the pos or neg terminal on my battery. So in this case, one of them would be unplugged. Which one?
Old Mar 17, 2006 | 04:21 AM
Slows2k's Avatar
It's normal to see a small spark when connecting the ground cable to a battery, you are completing the car's main electrical circuit.
As far as a grounding "system" doing anything, the only thing they are effective at is making the car heavier and your wallet lighter.
Old Mar 17, 2006 | 05:56 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Keep your money,and buy yourself a good lunch.
Old Mar 17, 2006 | 06:42 AM
Wisconsin S2k's Avatar
A grounding kit is about as useful as a turd on your shoulder.
Old Mar 17, 2006 | 09:09 AM
kent-k's Avatar
on a friends EG, we just grounded the VTEC solenoid. it made the solenoid engage hardere, it seemed. the other grounds seem useless.
Old Mar 17, 2006 | 09:28 AM
[QUOTE=kent-k,Mar 17 2006, 12:09 PM] on a friends EG, we just grounded the VTEC solenoid.
REVZ TO9's Avatar
Banned
how do I ground the VTEC solenoid? Where is it? Got pics? I would only use one wire then if I chose to ground that only?
Old Mar 17, 2006 | 09:29 AM
don't bother. please read my post above.
it's as useful as running a grounding wire from your nuts to your steering wheel.
Old Mar 17, 2006 | 09:44 AM
REVZ TO9's Avatar
Banned
haha! ok
Old Mar 17, 2006 | 11:40 AM
KennyS2K's Avatar
just a thought, i may be wrong, but..........
your alternator produces a/c which is then rectified and regulated internally to 13+ volt d/c. This runs your ignition, not your battery. your battery is a storage battery and meant for vehicle starting and then the electronics are engine powered.
your alternator is grounded by being bolted directly to your engine block. your spark plugs are grounded by being threaded directly into the head. sounds to me like a pretty good ground system as is.
d/c current flows from negative to positive in a complete loop. why not pay attention to the positive side of the loop?
grounding may be of help for accessories using the body as a ground.
