Is it hard to install a diff
Old Nov 22, 2006 | 05:36 PM
Silver S2k4's Avatar
Default Is it hard to install a diff
My diff went up so I am in the process of buying a new one and though that i could get together with my well experienced friend and swap the diffs.
My question was whether it is hard to install a diff. Any tips or tricks or anything i would need to know?
thanks
Old Nov 22, 2006 | 06:19 PM
negcamber's Avatar
Check the FAQ and search...I recall xviper had a write up on installing gears, which would also include instructions on removing the diff.
I can tell you that removing the axles is not that tough (also a write up in the FAQ). Would imagine that after the axles you'd then pull the drive shaft away and unbolt from the diff mounts.
Old Nov 22, 2006 | 07:55 PM
Spec_Ops2087's Avatar
Its not hard at all as long as you either have someone who has done it or you read something to tell you what to do. Luckly, I had billman help me and it was a pretty straight forward process. The diff itself is only held in by like 5 big bolts. The annoying part is removing the driveshaft and just disconnecting the axles (you don't have to completly remove them).
Old Nov 23, 2006 | 01:01 AM
SpitfireS's Avatar
negcamber Posted on Nov 23 2006, 04:19 AM
, it does include those instructions.
Look here:
https://www.s2ki.com/forums/index.php?showtopic=85687
Installing is the same operation in reverse order.
Succes.
Old Nov 23, 2006 | 08:26 PM
Thanks a lot to everyone, I think I might attempt to install my diff myself.
Old Nov 23, 2006 | 08:40 PM
us2bwrx's Avatar
its fairly easy, ive done like 3, 1 beeing my own. like someone said above, make sure u have someone with you to help lift it if u dont have a jack
Old Nov 24, 2006 | 05:44 AM
Squeezer's Avatar
i've done it myself twice. make sure to stop by the dealer and buy the ball joint popper
Old Nov 24, 2006 | 06:19 AM
SpitfireS's Avatar
Silver S2k4 Posted on Nov 23 2006, 03:36 AM
My diff went up so I am in the process of buying a new one.....
.... Any tips or tricks or anything i would need to know?
A new one as in brand new or another one?
Just asking because the propshaft companion flange is different on 00-03 (IIRC) models.
In your sig it says MY04 so you should have no problem with 04-later.
Is it in allready?
What happened with your old diff?
How did it "go up"?
Old Nov 24, 2006 | 06:47 AM
stylinhonda's Avatar
Stupid Newb Question. What happens when your Diff goes? Signs etc? A guy local has replaced his 5 times. Is that bad of a driver lol?
j_c_a's Avatar
It's not a bad idea to go ahead and order replacements for those allenhead bolts on the driveshaft flange. There's a real good chance that one or more will get rounded out when your remove them.
