Hard knock sound, -01 F20C
Greetings from Finland, fellow hobbyist!
My first post, but been reading the forum to solve problems since i purchased my s2000 couple years ago.
Few weeks back all of sudden my 2001 s2000 developed a really nasty sounding knock. First i thought it was the timing chain tensioner, i just replaced it with a new original part from Japan; didin't help.
On idle it sounds okay, but starts to knock when opening the throttle valve
https://www.youtube.com/watch?v=hWK8...ature=youtu.be
Any ideas? or should i film a better / longer video?
All great greatly appreciated!
Never, it had a perfect maintenance record upon buying and has been working great until this point.
By intuition i'd imagine sound like this is coming from slow moving parts, wouldn't imagine valves as the first place to look for?
Longer video, if it helps any. Sound is a lot nastier to bear ears, dosent really translate that well into the video.
Im afraid it sounds very much like a rod knock..
Sounds like rod knock..........does it get louder under load and then almost go away as it spins down? Don't drive the car a lot till you figure it out.
When this happened to me I noticed driving it got louder as I accelerated and soon as I let off gas and left in gear so there was no load or almost engine breaking it went away COMPLETELY. Then soon as you got on it again.....LOUD. That's a spun bearing on your crank.
Other thing to check is your spark plugs. Make sure they are all secure and bottom electrode is intact.
ReedDerek
Feb 15, 2011 06:08 PM
