HARDTOP question
Old May 12, 2007 | 10:19 AM
chong2k's Avatar
Default HARDTOP question
ok so im finally taking out the soft top... but will i need a different set of side catchers? because doesnt the oem ones bolt on to a part of the soft top hardware? correct me if im wrong because i probably am. thanks in advance for any info.
Old May 12, 2007 | 10:30 AM
a_zepeda926's Avatar
i dont think it is... im lookin at the diagrams in my Honda service manual and it looks to be a whole unit that is bolted to the body. if you want i can scan it and email it to you.
Old May 12, 2007 | 01:57 PM
chong2k's Avatar
if you can thanks... chongalong@tmail.com
Old May 13, 2007 | 09:11 AM
neveronlines2k's Avatar
One member told me, I would need to add spacers/ washers where the side cathers are when gutting the soft top. Another freind said I would not need to add spacers/washers (both are running hard tops without soft tops ).
I will be gutting mine too and will post what we needed to do (may be a little while before I gut it though ). I will watch this thread to see what I need to do to make everything fit right.
Old May 13, 2007 | 09:28 AM
lilazngrl4o8's Avatar
I don't know about removing the soft top, but the oem hardtop needs side catchers that are bolted onto the body of the car..
Old May 13, 2007 | 05:04 PM
chong2k's Avatar
i should probably be gutting it tomorrow... so ill let you know and try and get some pics up if i do so..
Old May 13, 2007 | 05:55 PM
i tried emailing you the scanned pages but it didnt go through.. i got an error message from yahoo
Old May 13, 2007 | 06:23 PM
Stratocaster's Avatar
The rear catchers have 4 bolts each. Two of the bolts mount to the car body and the other two mount to the softtop frames if I remember correctly. The two are enough to mount the hardtop. I had my HT installed like that for a week or two. I never drove that car because it had no motor at the time. But it looked to be held on just fine.
sohailnisar
Jan 23, 2016 11:40 AM
RagingCheese
Oct 14, 2013 05:54 PM
Suzuka AP2
Nov 7, 2011 05:47 AM
s2kayyyy
Mar 1, 2011 09:00 PM
stevedrakeuk
Aug 19, 2002 04:43 AM
