Have anybody install a Fuel Presure Gauge? Where the sensor goes?
Honda's remove the damper from the fuel rail, and connect a gauge in there. The service manual lists a part number for an adaptor that goes in place of the damper to allow the gauge to be connected. PITA!
-Brian.
-Brian.
Originally posted by s2000turbo
Bmarshall: Where is the fuel rail damper located?
unfortunately I had clearance problems so I had to drill/tap into the fuel rail and thread a 1/4 inch opening. The tap was about 1.5 inches from the end of the fuel rail (closest part to the nose of the car). At that point I fitted a tee (not necessary for your application) and then attached the fuel pressure sensor unit which sends an electrical signal to the fuel pressure guage. Make certain you use compressed air to blow out the fuel rail when you are finish tapping and used teflon paste when attaching all the fitting (do not over do it though). I also used brass fittings. The fuel pressure is anywhere from 46psi to 53psi.
I rang Honda Aus about the adaptor that fits in place of the damper and they said it wasn't available. Whether they mean in Aus or globally I'm not sure.
My tuner removed the damper altogether and put a connector there.
