head light adjustment
Old Jul 21, 2009 | 06:14 PM
phinsn98's Avatar
Default head light adjustment
I just had the headlight enclousres replaced under warranty (the clear coating or what ever it is was coming off). That being said the head lights were not alligned properly. I've read multiple posts about the passenger side supposed to be higher and it is. The problem is I had a perfect cut off straight across before the factory lenses were replaced and now I have a ____ \____/ and the passenger bulb is much dimmer then the drivers side. The passenger side looks like what ever creates the cutoff on the bulb is no longer there.
Can anyone provide me with some advice on this?
I'd like to see some pictures of other headlights against a wall...there gonna think I'm crazy at the dealership but I sware the cutoff was perfect.
Old Jul 22, 2009 | 08:07 AM
phinsn98's Avatar
Well I got my answer although haven't tested it tonight. I got a few different responses to what was wrong.
1) bad bulb
2) bulb inserted improperly
3) allignment was wrong
I think it's number 2 because when ever I've worked with HID kits the cutoff (hood) sits over the top of the bulb and this definitly looked like the hood was on the bottom instead of the top.
Old Sep 26, 2009 | 10:44 AM
ssthrd's Avatar
https://www.s2ki.com/forums/index.ph...&f=22&t=731898
Sounds like we have something in common. check the thread above.
Old Oct 14, 2009 | 05:05 PM
ssthrd's Avatar
Curious to know what you found out?
esafaeian
Apr 6, 2016 01:46 PM
jXxviii
May 12, 2012 01:09 AM
shkani04
Dec 5, 2011 04:49 AM
SwansS2K
Nov 7, 2006 02:53 PM
Chitah831
Apr 2, 2005 06:54 PM
