Head stud question??
Old Dec 15, 2003 | 04:25 PM
xs2kboyx's Avatar
Default Head stud question??
Im currently turbo charging my car and I was just wondering how much boost or Hp can the the stock head studs hold ?
Old Dec 16, 2003 | 10:58 AM
S2000PR's Avatar
I have stock internals and i have 432hp at the wheels at 13psi.
Old Dec 17, 2003 | 02:09 AM
Eugeneo's Avatar
The head bolts in a F20c look almost twice as strong as the ones in a b18c
Old Dec 17, 2003 | 04:57 AM
xs2kboyx's Avatar
Now thats very impressive . How are you boosting so much ?When I had stock internals the max I was boosting was 7lbs .
Old Dec 17, 2003 | 05:04 AM
xs2kboyx's Avatar
Thanks anyways guys but I decided to go with AEBS studs .
Old Dec 17, 2003 | 06:13 AM
S2000PR's Avatar
[QUOTE]Originally posted by xs2kboyx
Now
Old Dec 17, 2003 | 03:48 PM
Mee's Avatar
Mee
Banned
when u go forced induction, there are alot of things that u need to consider. for starters begin with the compression. u will have to give up some of the compression in order to run generous amounts of boost, u can do that with just a thicker head gasket, i found that the copper once hold best under extreme heat. as for the head studs i would go with ARP if they manufacture any for this particular motor, it is a good investment and they are reusable, i have seen in some instances head bolts that stratch that are required to be changed every time the head comes off the block. arp head studs are forget, and thermal treated. u can use them as much as u want.
kevinboosted
Nov 12, 2011 07:12 AM
RedLineS2k10
Mar 19, 2010 07:01 PM
teddy11
Feb 26, 2009 01:42 PM
2gr84u
Jun 26, 2008 06:38 PM
03S2KAY
24
Nov 8, 2004 11:27 AM
